Aikouka
I was driving to work this morning, and the car in front of me braked rather suddenly, which caused me to focus on it to try and gauge the intensity of the braking (i.e. slowing down vs. stopping). Unfortunately, that meant that I missed the reason why he braked so suddenly: there was some debris in the road. I hit it with my front driver's side tire and as you can guess, the tire began to lose air. I pulled over, swapped it out with the "donut", and went to see if I could get a replacement. Well... as you can probably guess by me making this thread, my morning didn't get much better, because no one including the Ford dealer where I bought the car has the tire in stock. Essentially, I'm stuck with a donut on my car until Friday or Saturday when the dealer can get the tire in. I had them come down in price to closely match Tire Rack, so that's not bad.
Anyway, I'm just trying to avoid doing any potential long-term damage to components on the car. I read somewhere that you should consider swapping one of your car's good wheels if the bad tire is on a drive axle, which is the case for me. That makes sense to me, but is it good advice? The only thing that has me worried is that there's a 65 MPH road on the way home (only about 2.5 miles), and I recall that you should avoid taking a donut above 50 MPH.
In case anyone's wondering, my Altima had a full-sized spare, so I've never had to deal with a donut. Also, my luck appears to have run out, because I've never had a flat tire before this. 😛
