- Jun 18, 2001
- 105
- 0
- 0
Hey Everyone,
Here's the deal. I was running RH 7.2 on my desktop, and decided to go back to a dual boot because I needed decent CD burning software. I did a low level format of the master HDD to wipe out the GRUB boot loader, and then installed WinXP. Once the install was done, I started having wierd problems when the system would start or restart. Here's my hardware setup:
Duron 900 at 1GHz (It's been running at 1067, but I clocked it down cuz of all this)
MSI K7T266 Pro2
Alpha 8045
Maxtor 6GB (master)
IBM 40GB 60GXP (slave)
Plextor 24x10x40 CD-RW (master)
Sony 52x CD (slave)
Gainward GF2 MX400
Linksys 10/100 network
USR Modem
Enhance 350W PSU (with a panaflo fan)
I'd probably be really confused and even more agravated if it wasn't for the D-LED feature of this mobo. It hangs when restarting or from a full powerdown. The most common error reported by the DLED is: "Testing Real Time Clock". THe solution I've found is to turn off the PSU, and drain the power, and turn it back on. The other, more distubing, error reported is : "System on (The D-LED will hang here if the processor is damaged or not installed properly)". Ouch!!! There hasn't been any problems before. Only thing I could think of if that before this reinstall is that Linux had been running onthe system for about 2 weeks steady. I've also tried making sure all the cards and memory are plugged in tight. THe only thing I haven't tried is reseating the CPU. I figured I'd see what y'all had to say here before I unmounted everything just to unscrew the Alpha.
Thanx in advance!
Jazzman
MSI K7T266 Pro2
Alpha 8045
Maxtor 6GB (master)
Sony 52x CD (slave)
Gainward GF2 MX400
USR Modem
Thanx in advance!
Jazzman
