Pretty close to it. You'd lose some heat from light escaping, but it should be minimal.
also coil heaters are technically really similar to light bulbs so the idea is definitely viable.
The safest electric heat I know of is called a "baseboard heater."That said, I'd then base my decision on which unit is safest to operate. Does it have a tip-over switch? Does it have exposed elements that are hot enough to set a piece of paper on fire (or accumulated dust)?
Yup.wait... a hair dryer is as efficient as a space heater?
those things are dirt cheap at walmart
Pretty much everything is >99% efficient at generating heat. My computer is making heat, the monitor makes heat. Server rooms have huge hvac systems to deal with all the heat. It's nice because it means any electrical device can be used to heat a room. It also means the only difference between different heaters is their other features like thermostat controls, fan speeds, timers, etc.Yup.
Pass electricity through resistance, and you get heat.
Heat generated = Current² * Resistance
Watts = Amps² * Ohms
CO poisoning?
Actually, you could run the exhaust from a car through a heat exchange in the house. Its like a gas furnace :-D
Put a sterling engine in your heater to produce more electricity to produce more heat then add another sterling engine and keep going.
Unlimited heat.![]()
http://www.cbsnews.com/stories/2005/02/09/earlyshow/contributors/dannylipford/main672592.shtmlCeramic heaters are some of the newest convection heaters on the market. These heaters have ceramic plates and aluminum baffles. When electricity passes through the ceramic, it is heated. The heat is then absorbed by the aluminum and a fan blows the hot air into your room.
Ceramic heaters are easily portable and give off a great deal of heat from a small box. These heaters tend to be more energy efficient and safer than many heaters, so even though they heat up quickly, their plastic casings stay cool. A great use for this type of fan would be in a small office or tabletop.
The only downside then is if you've got an available heat source that's cheaper per-watt/hr than electricity.Pretty much everything is >99% efficient at generating heat. My computer is making heat, the monitor makes heat. Server rooms have huge hvac systems to deal with all the heat. It's nice because it means any electrical device can be used to heat a room. It also means the only difference between different heaters is their other features like thermostat controls, fan speeds, timers, etc.
A toaster oven would make a good room heater. It's small, it's fairly high energy, it's built to run continuously with temperatures exceeding 450F, and it requires no active cooling. Start it with a 5 minute timer and the room will get nice and toasty :awe:
Safety, and the concentration and delivery of the heat.http://www.cbsnews.com/stories/2005/02/09/earlyshow/contributors/dannylipford/main672592.shtml
It's more about safety and, to a lesser degree, efficiency vs heat output.
Maybe it also replicates bacon - and cooks it.How does that work? It sounds like magic.
I have an infrared heater. Unlike most heaters which are sort of like a toaster, infrared generate infrared rays which heat the room like the sun vs burning the air... That means you don't lose any humidity in the air, which is common in winter because most heating systems are burning the air and result in dry skin, etc.
Actually, burning the air would make it MORE humid. Hot air can hold more water than cold air.
Efficiency, again, is going to be as near to 100% as you can get.
1500W in, and you're going to get damn close to 1500W out. (Where else would the energy go, anyway? Minute rearrangements of a few atoms in the crystal structure of the metal in the wires?)
Concentration: Tiny, fast fan vs a large slow one.
Delivery: Radiation, natural convection, or forced convection.
Or maybe it doesn't feel as dry. Where would the moisture go? The only thing that would change is the relative humidity, as the air in the room gets warmer.I have an infrared heater. Unlike most heaters which are sort of like a toaster, infrared generate infrared rays which heat the room like the sun vs burning the air... That means you don't lose any humidity in the air, which is common in winter because most heating systems are burning the air and result in dry skin, etc.
(Thats what it said on the box, can't say if it was the truth or not)
Where does the extra energy go then?Efficient? Yes. Near 100%? Impossible. Carnot efficiency rules, the ultimate efficiency of anything that does work is dependent upon the temperature of the heat source, and the heat sink. In this case, a 450 degree toaster and a 70 degree room, for example. Converting to Kelvins first, the equation is
Efficiency = 1 - (21/232) = .909 or 91% efficiency.
Purely academic, but true.
