I have a 240mm rad with the stock XSPC fans that came with my kit currently. They are standard 3 pin fans and I power them both (using 3 pin splitter) off the CPU 3 pin connector from my motherboard (Asrock Z77 Extreme 4, has both 4 pin PWM and standard 3 pin cpu fan connectors). I have auto fan controlled according to CPU temp configured in Bios, and it works fine through the 3 pin connector.
I decided recently to replace the fans with Corsair SP120 perfomance edition fans, these are available as both 3 pin and PWM.
What´s the advantage of getting PWM fans when 3 pin fans are also auto controlled by my mobo? Am I missing something?
