I have a Celeron 633 CCO stepping 1.7V default.
My mobo, a SOYO SY-7VCA allows voltage adjustment in the range of +1.5%, +3.5%, +5.0%, +7.5%, +9.0%, and +10%. With the default voltage at 1.7V, the highest I can get with the +10% is 1.84V! Duh!!
I was trying to do 950(9.5x100)@1.84V and it made it all the way to loading Windows, but crashed giving errors loading..blah..blah... One step down to 903(9.5x95) and it's working beautifully!!
I should be able to do 950 if I can bump the voltage up to 1.9V...chances are pretty good rite? But my mobo... the voltage adjustment just doesn't make sense... max 0.14V increment??
The mobo is jumperless, can a BIOS fix give me higher voltage adjustment?? Or is it simply a hardware limitation of the board??
I love the 7VCA...but the voltage adjustment suxx!!
I was hoping to get some feedback before I contact SOYO tech support.
Thanks alot!!
