Recently bought a Soyo 5EHM socket 7 baby AT motherboard on eBay. I know it's an old board, but I was looking for a cheap mobo replacment for my parents comp. Their old board bit the dust. I will list the specs on the other components is below.
Here's the problem...
I can't get anything when the computer is turned on. The power works and the fans inside run fine. The computer sounds like it is booting up (faint clicking sound, like it is checking the RAM), but I get nothing on the screen. I think it is a video problem. I verified that the video card and monitor work using another machine. Could it be the AGP slot? Or is there something else wrong?
Soyo SY-5EHM rev1.2
(socket 7, AT, VIA MVP3 chipset, AGP, 3 PCI, 3 ISA, 100MHz bus)
AMD K6-2 300MHz. (will be upgraded to K6-2+ 450 soon)
128MB PC100 RAM (works in other machine)
Diamind TNT2 Ultra 32MB video card
8.4GB Samsung 5400RPM hard drive
230W AT power supply
3.5" floppy
That's it! I stripped it down to the bare minimum to make sure there weren't other drives/boards causing problems.
Soyo SY-5EHM rev1.2
3.5" floppy
