soyo mb...udma problem
ron2368
I installed a Soyo mb that supports udma 33/66 and am using a maxtor udma 66 hd. The bios is set to auto detect for the harddrives. When the computer boots up I notice that the drive is only detected as udma 33. I am also getting a line message during bios boot up saying
"primary IDE no 80 conductor cable installed"
Whats the deal with this message?
Is there a special cable type for udma 66. I am assuming the above 2 things are related. I dont see a specific bios setting for udma 66 instead of the auto setting. Do I need a new cable I am using the one supplied with the new mb?
Thank you
RC
I'm not sure what Soyo board you have or what cables are supplied with what Soyo board, but from my experience, you are not using a UDMA66 cable for the main drive and primary ide on the motherboard. That is the only time I have ever seen that message. Check to make sure you have the proper high density cable - get with where you got the board and make sure you get the correct one if not.
To have the HD work in ata66 mode, you will have to use the 80conductor IDE cable, not the normal 40 conductor ata33 cables the we normally use.
Thanks, though I am not sure of the solution, I am getting a new udma 66/100 cable. Using the system now is fine, BUT Norton 2000 keeps losing dll's and becoming partially unusable. If I use speedisk, NU gets totally wacked, a few seconds later Explorer crashes and I have to reinstall win 98.
These problems only happen with these disk intensive programs, everything else works fine. I think after I get the new cable I will put NU back on it to see if it crashes. Hope it goes away!!!
Never use soyo again, I have a gigabyte and very smooth. Why would soyo provide a udma 33 cable with a motherboard that they rate at udma 66????
First off: What Soyo Mobo are you using?
2nd: What IDE connector do you have this drive on. I believe 3&4 are for 66, 1&2 are for 33. Check your manual though because I could have that switched.
3rd: Are there HighPoint drivers you need to install? If you don't install them, your drive will be operating in MS-DOS compatability mode, which could be the cause of your Norton problems.
4th: Soyo usually ships an ATA-33 and 66 cable with it's boards. The 66 is blue, the 33 is grey.
5th: You're cetainly welcome to never use Soyo again. However, a lot of people on this board and others think Soyo makes a grat board. The Soyo 6ba+iv is probably one of the better BX boards ever produced.
the board is a sy-7IWM/L. I fixed the problem and it was cable related.
This is my first time doing this and I really had many problems but learned alot from having them. Also forum members have been really helpful whenever I ran into problems. Most were due to my inexperience.
There is no new bios for the board as far as I can tell. I did download a few driver/chipset updates but may wait till next week to install since as of this am I think everything is ironed out .
I am still not impressed with soyo, I called their tech support 3 times and other than 1 straightforward answer felt they were as lost as me. Some may be my fault too. Besides they had such heavy asian dialect I could hardly understand them. Ended up ok though and learned alot.
biggest lesson I learned....thought I just would plug in the parts and it would work.....wrong pay attention to details.
