JEDI
got this board from microcenter bargain bin (~$20). when it came, the seal on the static bag was broken. so that meant someone else returned it. unfortunately, i didnt have time back then.
3 months later, i finally started playing with it.
everything works, except the lan. I got the latest lan driver from VIA.
"Via Rhine II Fast Ethernet Adapter"
it says "network cable unplugged" when i have a cable connected to it. this cable works with laptop.
so i set it from Auto to 100baseTX. Same. Then i set it to 10baseTx. Now it sees the cable, but i get the yellow triangle with exclamation point saying "limited or no connectivity." but the cable works on my laptop, and i can surf the web w/my laptop.
Any ideas on how to fix the Lan problem? (and no, cant return to microcenter, and i think soyo is out of business)
THX
edit:
DSL
THX
edit:
DSL
