Soyo Dragon Plus and AthlonX 1700 problem:
First this is my setup.
Soyo dragon plus with latestbios update
AMD XP 1700 Cpu
Heatsink Thermatake S-K6 + D38 Fan
Thermal paste Artic Silver II
Extasy GForce 3 TI 200 64 megs video card
256 ddr Crucial memory stick
Adaptec SCSI and Scsi drive
Lite-on 24x CDRW
I am not able to run at full speed with my new athlon xp1700
I am only able to run at the CPU Frequency Select=100 default value with the CPU ratio selected as AUTO, but this is not the full speed of the CPU (1467). I tried Frequency Stepping increments but I can only get pass 118 fsb then I get windows protection errors or lockup so bad I have to reset the bios.
I also tried the CPU Frequency Select=133 default value, It wil not boot.
I have not played with core voltages or Memory settings since it will make it a lot more complicated to resolve this issues.
CPU temp is 52C iddle.
Also read this thread
http://forum.ocworkbench.com/ocwbcgi/ultimatebb.cgi?ubb=get_topic&f=33&t=000020
The fan that comes with the heatsink, Delta D38 (Specs: 6800 RPM, 38 CFM, 46 Dba. Daul Ball Bearing) extremely noisy, Does anyone have an alternative, to replace it with, the noise its driving me crazy
Does anyone have any clues?
Also can you post your bios settings if you have a similar setup?:|
AMD XP 1700 Cpu
Lite-on 24x CDRW
