SOYO Dragon + NIC Problem
ShadowFox
304
Hey, i'm having trouble with the integrated NIC on my new Dragon +. It hardly works: sometimes it shows up on my network(in network neighborhood) but i cant access any of the shared drives, none of my other comps show up with it. I've tried all the different spped settings... (100tx full duplex to 10t half duplex) anyone else have this problem? What can i do, or should i just RMA it? (yes i have the newest bios and NIC drivers)
Windogg
First isolate the problem. Are you sure it is hardware related or do you think its software related? What colors are the LEDs on theport?Have you tried pinging other systems on your network? What are your system specs? What OS are you running? Are you sure your network is setup properly?
RMAs should always be a last resort.
Windogg
ShadowFox
304
I'm running win2k, the led's on my 5 port hub show normal operation, nic led is lit up, i think my network setup is fine, its set up just like my other win2k machine
specs:
athlon xp 1700
512mb mushkin high perf ddr
soyo dragon +
ibm deskstar
radeon 7500
plextor 24-10-40
floppy
100mb zip
