- Oct 19, 2000
- 17,860
- 4
- 81
Hey guys, I'm having a problem specifically with my mobo and video card. Here are my specs to get you familiar with the system:
Athlon 1700+ @ 1800+
512 DDR Mushkin High Performance Rev 2 - 1 stick
Soyo SY-K7V Dragon Mobo
2 - Seagate Barracuda Series IV 7200RPM 40GB
Radeon 8500 64MB Retail
Win XP Professional
*Just as a note, this 8500 worked fine in my Duron 700 system.*
Just got in my Radeon 8500, and I put it in, installed the drivers, and everything seemed fine. Within about 5 minutes of browsing the internet or downloading some files, it completely locks up. By this, I mean either I'm loading a page or watching a file download, and sometimes the screen will go slightly blurry or just stop completely. Most of the time, it will reboot, although a couple of times I have had to reboot myself.
Here are a couple of things I've tried. First went into BIOS, and set back to default processor speed, but heat has never been an issue in my Lian-Li PC-65. CPU was at 42C and case temp was at 34C. Nothing wrong there. Still locked up with this config. Then underclocked the processor in BIOS to the 'Fail-Safe Bootup' option, which knocked it down to 1.1Ghz. Still locked up with this config.
After realizing it wasn't the processor or heat issue, (because everything in the case is cool to the touch), I turned to the ATI drivers. The problems with the drivers is why I almost didn't go with ATI in the first place, but I chanced it anyways. I have deleted drivers in safe mode, and reinstalled almost any drivers I could get my hands on, including the March 20th release from ATI. NOTHING works, still locks up with any and all drivers I try.
Third thing I looked into was the BIOS drivers, but Soyo has pretty much no updates to it's BIOS on it's update besides a 2100+ support BIOS update.
Is anyone else having this problem? What else can I check? I hope I don't have to take it back and get a GeForce4, but I will if I have to. Thanks for any suggestions or comments.
Win XP Professional
