SOYO Dragon + and Power-up problem
mted1
7
Has anybody else had a problem when the SOYO Dragon + 1st boots up and cycles the PS a couple of times?
When I 1st boot, I get the 1 beep from BIOS and then PS seems to restart (fans power down and then up). It does the 1 beep a few times with the power on/off and finally 2 beeps and starts running. I am going to try per-spinning the CPU fan to see if that helps since SOYO needs a fan signal on CPUFAN1.
I am using an Enermax EG365P-VE PS with this board and 1800+ and 3 sticks of Crucial 256 MB 2100 RAM and Philips Acoustic Edge and 2BA1 BIOS.
Once running system is super stable :)
Techno
This is funny... I got the same board, 3 sticks of Crucial, same power supply, Athlon XP, and same bios. When turning on my computer i hear 2 beeps about 5-7 seconds apart, then the monitor turns on, then it goes to reading the bios and then a 3rd beep.
My system seems to run fine (for the past 7 hours i had it running)
Smith
104
The Dragon + startup is a bit different from the norm.
One loud beep, followed by two short beeps then video is NORMAL for this board. I checked this
with John Howland who is a Soyo guru of sorts.
If you hear anything else there could be a problem. If you hear NO beeps but fans are moving
it may be a video card not seated properly. You may also hear your PS cycle down and up with
the fans.
rondeemc
1,216
I am considering buying this board and am curious.......doesn't the on-board led show normal progress during this progression of beeps?
Edit
Nevermind...forgot that was on the MSI and Epox boards, not the Soyo
zOmbiebOy
1,072
Mine does the same thing. I thought the power supply wasn't giving the system enough juice so I upgraded to a 350W Sparkle PS. Unfortunately, that didn't stop the behavior mted1 describes. :(
-z
