Soyo 6BA+IV and PIII 700E @ 933.. Will it work?
CraigRT
31,440
hey people, right now i am using an Asus P3B-F, and my 700E just will not do 933.
hell it won't even do 866 well. (games will crash)
I was wondering if i tried a 6BA+IV that i just picked up cheap if it would work on that. any ideas?
I'd really like to know if someone has the same setup out there, it'd be encouraging to know it'd work for me.
I also have a TNT2 Ultra which seems to work at the high AGP BUS cause it almost boots all the way into windows. so that shouldn't be the problem, and also i have PC133 SDRAM.
Thanks!!!
zOmbiebOy
1,072
Hey Yield, I've got this setup cranking away with no problems. Just make sure you use the slocket jumpers to change the voltage because the Soyo bios doesn't let you increase the voltage in numerical increments, only percentage increases.
Hope this helps.
-z
