Soyo 17" LCD Flat 17" LCD monitor
OneWatt
DYLT-1767 17" LCD monitor
LCD Type: 17.0 color TFT active matrix SXGA LCD
? Contrast Ratio: 450:1
? Viewing Angle: 160 degrees horizontal, 140 degrees vertical
? Response Time: 8ms
? Brightness: 250 nits
? Display Colors: 16.7 million
? Pixel Pitch: 0.26mm
? Video Input: Analog RGB
? Connector: 15-pin mini D-sub
? Integrated Speakers: Yes
? Dimensions: 12.1"w x 15.3"h x 1.56"d
? Weight: 7.26
? Color: Black
Display
Monitor Size 17in.
Viewable Size (inches) 17
Pixel Pitch .264 mm
Maximum Resolution 1280 x 1024
Contrast Ratio 450:1
Connectors/Casing
Video Connector 15-pin mini D-sub
Speakers ? Integrated Speakers
TV Tuner integrated? No
Case Color Black
Additional Information
Weight (lbs) 7.26
Width (inches) 12.1
Height (inches) 15.3
Depth (inches) 1.56
Manufacturer Information
Parts Warranty 2 years
Labor Warranty 2 years
Offer good through Jul 31 2006 11:59PM PST.
http://www.ecost.com/ecost/ecmac/shop/detail~dpno~7003190~Action~Detail.asp
Found this wile I was looking Around
OneWatt
Soyo rebates are infamous for not getting fulfilled. Just google it and you will see.
Many people here at ATHDs will probably tell the same thing to you. The ones that got hooked into the SOYO motherboard deals from Newegg, Microcenter, etc. They might have a reputation that's worse than TD rebates. Not crapping, just warning you and others about the potential for Soyo's customer abuse.
Not crapping either, but took me a year to get a soyo rebate on a bundle from TD - it was Soya, not TD. I would ask myself if $150.00 is a good price, because I would not count on getting the rebate.
how is soyo still in business?
after a bad experience with their mobo and rebate, I havnet bought anything soyo since.
