- Jul 17, 2004
- 1,375
- 0
- 0
Assuming this is the correct forum to ask in, and that I haven't missed some thread once-stickied and now sinking out of sight, the HTPC project here at my place has run into a minor roadblock . .
So far, the PSU's I've found either at retail locally or on the net offering above 250 watts are one of two things I can't use: sub-quality (or an unknown that may *be* sub-quality), else the mounting side faces the wrong way. The mount end measures 2 1/2 by 4 inches, being deeper than it is wide. Fox example, the Enermax 270 watt unit is the same overall physical size, but mounts on the longer 5 inch side instead.
