This isn't really a cooling question as much as it is a fan noise question. I recently purchased a 3Com SuperStack II Switch for my home lab and I'm looking to replace the two 60mm fans in it that scream at a mind-numbing 40+ dba each.
The problem I'm having is that the fans use a two-pin connector (like a PSU fan). I know I can cut the ends off the old fans and splice the wires, but I'm too anal to be comfortable with that.
Does anybody know where I can find these two-pin connectors? Also, do the wires need to be crimped or soldered into the connector?
Thanks!
Thanks!
