sound won't play!
habib89
i installed a nintendo ds emulator, and now my sound doesn't work.. i reinstalled drivers already, so i'm not sure what else i can do... could it be possible for bad software to somehow mess up my sound? my computer still thinks that the sound works... anyone have any suggestions for me?
and i don't need comments on how i shouldn't be installing emulators cause they're illegal etc etc.... i learned my lesson.. just please help! thank you!
If you're using XP, just use System Restore and go back to a date before you installed the emulator. Hopefully you're not one of the people that has disabled system restore (no good reason to do that).
Start/Programs/Accessories/System Tools/System Restore
thanks for the suggestion... it didn't work, however... well in a way it did.. so after i did a restore, i shut my computer down.. then as i was closing the cover to my laptop, i heard sound!! apparently it seems like it might be a physical problem.. i can only get sound when my screen is almost all the way closed.. so i guess i just gotta look in my manual or contact dell for schematics
by the way, it's a dell 700m...
