- Feb 3, 2005
- 7,326
- 2
- 76
A couple days ago I installed a Blaupunkt THA475 amp for my speakers, and I've noticed quite a few things that just don't sound as good as I think they should. In fact, at this point I rather wish I had just left my speakers hooked up to my HU.
- Certain parts of songs are missing, as it it's just cutting them out (maybe a frequency range or something?)...for example, Children of Bodom's "Tie My Rope" starts with a synth intro, then brings in a quiet distorted guitar sound that is quite noticeable, but I can't hear it anymore. Also, on Lamb of God's "Laid to Rest", it's hard to notice the guitars and exactly what they're playing (in the intro, there's a sort of higher part that's played before the vocal parts...you can barely hear it).
- My speakers distort at MUCH lower volumes than before (I can barely do 27/34 with my amp, where as I could do almost 30/34 before noticing bad distortion with my HU...)
- My speakers don't get as loud as they used to (and, as mentioned above, setting up the gain to correct this just brings in the distortion)
- Vocals stand out way too much now (too hard to fix with an EQ...vocals are mostly metal/screaming)
- Speakers seem to have even less bass than off the HU
My current setup is like this:
Sony CDX-GT100 HU, which outputs RCA cables to my Blaupunkt 275 sub amp (which powers my 12" Blaupunkt sub). The sub amp outputs to my speaker amp, which is currently only set to power the front speakers and nothing else (I had it running through an EQ, which would then enable me to run RCA cables to the front and rear section of the speaker amp, but I noticed more distortion there).
My speaker amp is currently set to provide 75 watts RMS each to my front speakers. My front speakers are Boston Acoustic SX65s (2-50 watts RMS).
I'm fairly positive I did all of my wiring correctly (speaker wire is 12 gauge, btw), and I'm also fairly sure my crossover/frequency settings and gain settings are properly set on my amps.
So, why am I so disappointed with my new speaker amp? My first guess would be that it's too overpowering for my front speakers, causing them to distort and such. What are some possible causes of these problems?
