When I listen to a sound file in WMP everything is fine unless I fast forward by draggin the slider furtherinto the file. Then the volume goes to a very high level?????
I had this problem before after I installed sp2 for XP. A forum member suggested I unistall/reinstall my audio drivers and it fixed the issue at that time.
The problem is I have had this install for several weeks and have made no changes to my system at all.
So before i unistall/reinstall, is there any other way to try and remedy this issue?
thanks.
thanks.
