Sound question
zmaster
342
hi guys,
this is a rather specific question so please bear with me.
i have a home PC that i wish to use as a main hub for all my data (already has 20+tb of storage space).
in the past i used a logitech z5500 speaker system that connected to it, and a 2screens+projector set up.
now that i moved countries i wish to set up something better.
i will need sound in the bedroom with possible wireless (power cabled) sound to the bathroom.
i was thinking one of two options
1. 5450 equivalent where the wireless speakers plug into the power plug in the bathroom.
2. set up a sound system cabling through to the bedroom with extender speakers to the bathroom (i have headphones logitech g530 wireless when i use the main PC).
does anyone have any ideas what i can do to get the above system set up
i drew a crude diagram of what (excuse my shocking paint skills)
sdifox
101,206
18,220
how far is the bathroom? BT might be an option.
ethernet over power into the bathroom is not really a good idea :p
zmaster
342
apartment is about 100m2 all in all...so with proper cabling about 10m to the bathroom...my concern is how to link up the bt speaker to the main rig...
sdifox
101,206
18,220
bt can be added to computer. Is the 10 straight line or cabling? 10m is probably too much for bt considering walls and stuff.
JAG87
3,921
Personally IMO when it comes to wireless stereo audio, the best and easiest solution is Airplay, even if you have a Windows PC.
Buy as many Airport Express as you need and set them in Client mode. Try to find used ones on ebay for example, they can be bought for cheap. Connect them to your wifi network and then use either the Optical out (for a receiver) or Analog out (for just a set of speakers), depending on what your system can accept for input. Then buy something like Air Parrot for your windows PC, which is pretty inexpensive, and stream lossless 2 channel audio to your heart's content.
Better yet, find good airplay compatible speakers... if you're willing to replace your speakers.
