Sound Quality of Built-in TV Speakers?
Mermaidman
7,987
93
I'm thinking of buying this 46" LED LCD (only $1200!). It's one of those ultra thin TVs that measures 1.2" thick, and I'm wondering if the built-ins' sound quality would be even worse than the typical stock TV speakers. Is it even possible to get "big" sound out of a tiny cabinet?
Disclaimer: I'm not a sound enthusiast, so it's unlikely that I'll set up a home theatre, but I don't want noticeably bad sound either. At most, I might install a sound bar. Would appreciate your thoughts on this. If it matters, the TV room measures 17' long, 12' wide, and ~22' tall.
sdifox
99,137
17,462
built in speakers on tv are dirt cheap. Like 100bux for a tonne.
Rifter
751
pretty much all TV speakers suck, its a fact of life. you dont have to setup a home theater but a pair of bookshelf speakers will be a good idea.
kornphlake
1,567
9
Speakers need a box or cabinet with some volume to reproduce low frequencies. Small speakers are not physically capable of producing low frequencies. You don't need huge speakers or huge enclosures to get good sound, but you do need some volume that can't be contained in the housing of a flat panel television. That said, I thought the speakers on my television were adequate until I connected some real speakers, after I'd heard what television could sound like I always heard a tinny quality in the built in speakers. Unless you have heard something better for reference, you might not notice the inferior built in speakers sound bad.
electroju
182
Like others have said, TV have crappy speakers. You are better off using a stereo amplifier and any bookshelf speakers then hook it up to your TV. I do not recommend buying a soundbar because they also suck.
Use Amazon at your own risk because if the products fail who will you return the product. Also some brands require that you buy their products from an authorized dealer in order for their warranty to work.
JSt0rm
27,399
3,947
they mostly use a single driver to push all material and that sounds like balls mostly, mostly.
Corn
6,389
29
I've got a Hitachi LCD and by themselves, the TV speakers sound like complete crap as they had no bottom end at all. Then I found the subwoofer out jack on the back of the TV, hooked up an Energy sub I got at Costco for about $100 and it actually sounds pretty decent. Good enough for the kid and occasional TV show when the wife is hogging the real TV with her American Idol/Bachelor/whatever other reality show crap.......
alkemyst
83,769
19
Thin TV gives in to whatever speakers you need along the front wall. Since TV's began to get compact their internal speakers sucked.
Modelworks
16,240
7
Maybe if it were 3" or so there would be a chance but not with under 2" . There have been some pretty good designs where they locate the speakers in chambers and the sound is channeled to the front via tubes but I can't even see that working in something that thin.
NutBucket
27,126
613
Even when TVs were huge they had acceptable sound at best. The proliferation of flat panels hasn't helped things AT ALL.
kalrith
6,628
7
The only TVs that have half-way decent speakers are rptvs, but that's obviously out. I'd at the very least budget for a sound bar. $200 for a sound bar and subwoofer will be 50 times better than the flat-panel TV speakers (which still isn't saying much :)).
