Sound problems with Windows Media Player/CODECS.....
chronos1000
I have an ECS K7S5A, a DURON 1.0GHz and 256Mb DDR and I'm having some problems when using WMP. I can hear the Windows Sound when it starts up, Cd's using the default Win CD player and MP3 files using WINAMP, BUT....when I try to use the Windows Media Player or try to hear ANYthing via Internet, I have no sound!! The Windows Media Player and all streaming programs don't produce anysound. I read that I should check if the CODECS are installed and, in fact, one CODEC was not properly installed. Windows should download and install any missing CODEC that is necessary to play a music, but it simply ignores this CODEC. I've already checked the option to automatically download CODECS, but nothing happens...........wHAT CAN i DO??!
NEVERwinter
766
download the codec manually on microsoft's site. or get a codec pack somewhere... i know ones called NIMO Codec pack and TsunamiPack.
chronos1000
Actually, I've alrealdy tried to do that! But I've been searching the whole site for that CODEC (Windows Media Audio V8) and I just can't find it. I just found a help file telling me to go to the Add new hardware option and install the CODEC I need. The problem is that I don't have the option to install this specific CODEC, but only some others from MICROSOFT and as I don't have the file to install I just can't do it.
