When i try to play Serious Sam, all of the sounds coming from my left speaker are full of static, whereas if i unplug my left speaker and just use my right one, everything sounds fine. However, in UT or Undying, my sounds are screwed coming out of both speakers. I have eliminated the possiblility of faulty speakers (tried 3 dif. sets, and 2 pairs of headphones), i've tried 2 different sound cards, and the strange thing is i can listen to mp3s, wav or other sound files through windows and they sound crystal clear. I can also play older games like Quake or Worms 2 and the sound is fine. So, my question is, is there some decompressor or something that i need to install? I've reformatted my whole HD, and reinstalled everything, including drivers. I have tried every driver as well, so i'm pretty sure it's not a Sound card driver problems.
Another thing is that when i run a sound test thru direct x diagnostics, everything sounds fine until it gets to the hardware step. At that step i can hear the sound, but there is an odd ripping sound above the sound effects. Hard to explain, but again, i've ruled out the possibility of a hardware problem, so it seems it would have to be something on the software level. Any help will be greatly appreciated, i've tried everything i know of.
My system:
900Mhz T-bird
MSI K7T Pro with VIA KT133 chipset
128MB Ram
I/O Magic MagicSound PCI
ASUS V7700 Geforce 2 GTS 64mb
Direct X 8.0a (tried 7 and 6 as well)
My system:
900Mhz T-bird
128MB Ram
