Sound problems with 9800pro AIW
bimmer01
I hooked up everything to do the cable lines. I see the TV channels, but no sound comes out through my speakers. I have the Audigy 2.
Which cables do i need to hook up the sound.
DVI-I to VGA Adapter
Y-Power Extension Cable
Video/Audio Input Block
Component Video Output Dongle
Output Dongle
6? Composite Video Cable
6? S-Video Cable
Help me!!
...looking at the card from the back of the computer, the output to the immediate right of the dvi adapter, there should be a black connector that will plug into that port, and one of the leads from the black connector will plug into the "sound in" line on your sound card.
Voila.
You will have sound.
