Hi, i've built my pc myself using MSI KT4V motherboard, athlon xp 2200, with 512MB DDR RAM. And the sound card was built in.
I'm not sure whether i've installed everything properly. So my problem is this:
I can't separate both left or right channel of sounds from my pc. I can't filter out one of the channels sound since they both play on both side at the same time.
This mean i can't use karaoke mode in Power DVD or i can't get brain wave generator to work properly.
I already tried installed another cheaper Cmedia 8738 sound card and the result is the same.
Can someone please give me some hint as where to look for the solution to this problem?
