Here's the story:
My AN8-Ultra motherboard has no onboard sound, but came with its own proprietary card. I installed a Chaintech AV-710 instead and everything was fine until for no appearant reason I began to only get sound from my right speaker. I checked the connections (fine), put in another pair of speakers (still only right speaker), updated drivers (problem still exists), and checked Control Panel (everything was balanced).
However, I get sound when I plug the jack into the soundcard's ALT-OUT. The card was functioning, just not the way it was supposed to.
By now I was convinced that the card was defective, so I put in the soundcard that came with the computer. It worked before when I tested it, but now it didn't work at all. I uninstalled it, put the Chaintech back in, and now I wasn't getting any sound at all from the Line-Out either! The ALT-OUT however, still works.
I'd rather have the card function the way it's supposed to so I'm still trying to figure out what the problem is- and it seems like the problem isn't even related to the card? I even reformatted and did a clean install of Windows and the problem still exists so I don't think its a driver issue anymore.
So finally my questions are: Could this be a motherboard/BIOS issue that just spontaneously happened? How could I fix it? I've tried two different cards and the problem just got worse (one speaker to no speakers) so I have no idea what's going on. Any help would be greatly appreciated!
