Sound out to multiple devices at once
dawks
I'm wondering if theres anyway to output sound to my wired speakers, and bluetooth speakers at the same time in OS/X? Any hints?
I'm running Sound Source which makes switching outputs easy, but I'd like to have, two, or even 3 outputs going at once.
Thx
If you launch "Audio MIDI Setup" you can click the plus at the bottom and create an aggregate device.
The only problem is I don't believe you can control volume via OSX, or I haven't found a way.
Also, if you have Snow Leopard you can just Option+Click the sound menubar icon to change inputs easily.
