I think that maybe some expect too much from a material like dynamat. I have only ever used dynamat super, it has foil on the exposed surface. For me, it helped, but only a little. Fan selection appears to be the biggest issue. For my Antec sx1030, I used 4 pcp&c silencers, then ducted the alpha PAL6035 from the msi6309 to one of the rear fans. I may switch to a little more powerful fan here in the future. No more screaming 60mm YSTech! I noticed that when I touched the case, the sound changed. That is when I started in with the dynamat super, and kinda went nuts. Cleaned all surfaces with electro140. Covered the whole interior, didn't make much difference. Then I wrapped the outside perimeter of the fans with the little bit that was left, and voila, a noticeable difference. Not that it is much quieter, but the pitch is much lower, making it less annoying, to me, anyway. Dynamat does convert sound to heat, the actual temp rise is insignificant, and it does reduce heat transmission thru the case, not much of a problem for fan freaks. For anyone who has a 75db howling hoover of a cooling system, a few db isn't really noticeable. If anyone wants to knock a few db off of an already quiet system, using this stuff on the fan housings and panels that seem to vibrate might help, if only a little.
