Sound in XP
wholo5
I have no start or exit sounds in windows xp. All other sounds are working fine. Have tried all fixes I
can think of. Would welcome any help. Thanx
CraigRT
31,440
may i ask of importance?
i am sure the shutdown and startup sounds are not defined in the "sounds" option under "control panel"
wholo5
Well it isn`t important. I`m just more loveable when everything works as it should.
Big Lar
6,330
Have you: Gone into Control Panel/ Sounds, and made sure that whatever sound card you have is listed?
