Sound Hiccup in RtCW (now sound delay)
Spankthru
2,120
I have terrible sound delay that makes RtCW unplayable. Lowering the sound quality helps alittle but still a delay.
My system:
W98SE
1.4 Tbird
Abit KT7A Bios 64
Geforce 2MX 64mb v23.11 (doesn't like the latest 28.xx drivers)
Sound Blaster Live 5.1
Direct X 8.0
Not resolved under "recommend settings" or the lowest settings. Any ideas?
Maybe reinstall sound/video/directx/??
Just patched RtCW to v1.31
*update* Lowered graphic settings and now there is just a garbled echo of each sound.
Spankthru
2,120
Turned off Hardware Acceleration and works like a champ. Hope this helps someone
sep
2,553
<< Turned off Hardware Acceleration and works like a champ. Hope this helps someone >>
Where did you turn this off at, RTCW or OS? Did you lose any sound quality?
Spankthru
2,120
I turned this off in w98 control panel, through multimedia option.
No noticeable loss of sound quality.
Highest setting that worked was "Basic Acceleration"
