Accessories - Hard Drive
GALAXY Serial ATA-to-Ultra ATA adapter Retail
-Allows you to connect existing Ultra ATA 133/100/66 Hard Disk Drives to the latest Serial ATA host adapters.
-Plug into the 40-pin connector of hard disk drive directly, no PCI-slot is required.
-Compatible with various brands of Serial ATA host adapter more info>
N82E16813999704 $27.99
$27.99
Cases (Computer Cases, ATX Form)
Enermax CS-3051L-B3A (Black) Mid ATX Tower Case Aluminum/Plastic Front Panel w/ Acrylic Cover & Enermax Logo on side Window, Sound Sensitive Neon Light - Retail
Power Supply: Powerup 350W P4 Ready
$58.00
Memory (System Memory)
2xCORSAIR MEMORY XMS Extreme Memory Speed Series 256MB 32MX8 PC-3200C2 With Heat Spreader OEM
Specifications:
Speed 400MHz
Organization 64M x 64
CAS Latency 2-3-3-6-T1
$119.20
Motherboards - Intel
ABIT IC7, Intel 875P chipset for Socket 478 P4 Canterwood ATX motherboard RETAIL
Specifications:
Supported CPU:Intel® Pentium® 4 Socket 478 processors
Chipset:Intel® 875P / ICH5 RAID
FSB:800/533MHz 400FSB not Supported
RAM:4x 184pin Dual Channel DDR 400 Max 4GB ECC Support
IDE:2 x Ultra DMA 33/66/100 Connectors up to 4 Devices
$145.00
Processors
CPU: 2.4GHz
Type: Pentium 4 Northwood
Cache: 512K
BUS: 800 Mhz
$207.00
Video Cards
FIC Radeon 9500 Pro A95P OEM
Slot type: 8x, 4x
Chipset: RADEON 9500 Pro
Core Memory Clock: 275 MHz
Memory: 128Mb
Memory type: DDR
$175.00
Subtotal » $732.19
Grand Total » $ 753.19
I already have a ATA133 80gb @ 7200 w/ 8mb HDD at home and CD drives.
i'll buy another 1/2gig of ram and a sata drive and run raid0 later and i should be ready for doom]|[ (just barely😉) when its out
$27.99
$58.00
Specifications:
Speed 400MHz
$119.20
Specifications:
$145.00
Processors
CPU: 2.4GHz
Cache: 512K
BUS: 800 Mhz
$207.00
Video Cards
Slot type: 8x, 4x
Memory: 128Mb
Memory type: DDR
$175.00
Subtotal » $732.19
