Sound going crazy
Discussion in 'Home Theater PCs' started by Nihil688, Jul 9, 2017.
  1. Nihil688
    Nihil688 Member
    Apr 10, 2011
    70
    I have a YAMAHA RX-V673 connected via HDMI to one of my gpus for my home theater audio. I have had this setup for some time and everything's working ok until recently every time I power on my PC the amplifier isn't finding the speakers or at least it's not connecting them to the PC. If I swap out the HDMI to my second GPU whilst my PC is on then it works ok, if I don't it seems like it's barely trying to connect and at random sends out a massive static noise for a few seconds and then it stops, it happens also when Windows send out any kind of audio but not always.
    My question is, could it be the Yamaha causing the issue? Any way I can find what's wrong?
  2. Loading...
    Similar Threads - Sound crazy Forum Date
    HTPC and onboard sound Home Theater PCs Jun 7, 2016
    Creative Sound Blaster Z series not working with Tosklink/SPDIF Home Theater PCs Aug 4, 2015
    Best sound card for recording? Home Theater PCs May 10, 2015
    Sound card Home Theater PCs Jan 26, 2015
    WMC - spacebar driving me crazy Home Theater PCs Oct 13, 2013
  3. Nihil688
    Nihil688 Member
    Apr 10, 2011
    70
  4. sdifox
    sdifox No Lifer
    Sep 30, 2005
    66,027
    1,228
    Do you have other HDMI sources? Try it with the HDMI port you hook up to PC to see if you have the same issue. My bet is driver issue on PC.
