Sound Echo from TV Wonder VE
Connoisseur
2,470
I have my tv wonder ve hooked up to my satellite receiver. The video's working fine but my audio has an annoying echo, like i'm in a concert hall, which I can't stop. Is there any way to get rid of the echo? My specs are in my sig. I'm using ATI multimedia center.
Matthias99
8,808
You most likely have "record what you hear" (or a similar option) selected in your audio properties. Just futz around in the advanced panels of the volume controls until you find what to mute...
Connoisseur
2,470
But all the advanced options have is "Bass", "Treble", and "Digital out" selections. It echoes with or without digital out. BTW I'm using FPS2000's on an audigy 1.
Matthias99
8,808
No... it's one of the recording input options.
Go to 'Volume Control'/Options/Properties and switch it so you're adjusting the recording volumes, and make sure all the inputs are checked (so you can see all of the volume controls). One of those (the name varies depending on the OS and drivers you have installed; on my Win2K system, it's "Wave Out Mix") is the "record what your sound card is outputting" output. Mute it and the echoing should go away.
