Sound Cards
Absolution75
983
The X-FI you linked is kinda the de-facto soundcard to get, however it should be noted that you won't recieve a sound quality increase over onboard if you're just going to use optical (digital is digital).
terentenet
387
Yeah, for digital, go with an X-Fi. You can't go wrong with it since the card won't be responsible for the audio quality, but the receiver.
videogames101
6,783
27
If your using good, high impedance, headphones, the Asus Essence STX is THE card to get.
cmdrdredd
27,052
357
For a non-gamer the XFI is really a waste. The only reason to have it is for the EAX effects that AFAIK aren't on other sound cards.
isp
375
I'd go with the striker or possibly something from Asus...
murphyslabrat
314
LOL, that is a lot. I really like it....but I don't think that it would be in my budget....plus I'd have to get a firewire controller too.
And I said I like it, I mean I think it's REALLY cool.
As for the optical requirement, it's just for the speaker setup. My headphones are still using the regular jack.
