Alrighty, i picked up a sound blaster audigy 2 zs platinum, and i hooked it all up, and i just reformated, the onboard sound works, and i just installed all of the drivers on the disk, and there is no sound to be had, everything appears to be hooked up, but nothing is coming out of the card. Suggestions? Card broken? Do i need to turn stuff off in bios?
Also i just got a new MSI motherboard, Kv8 neo something something. If you guys need any of that information i can tell you.
Like i said though, the onboard sound works, so perhaps i hooked it up wrong, but when i run the diagnostic, it passes all the hardware tests. Thanks in advance.
