Sound Card Wierd Noises
Juice Box
9,615
I have an audigy 2 ZS sound card, and anything that gets plugged into it emits a VERY high pitch noise that gets louder when u increase the volume Any ideas?
when I mute the computer, it stops
KLin
30,958
1,082
Originally posted by: digitalsnare
Originally posted by: Pepsi90919
mute the computer? :confused:
when I mute it, it stops
get a different sound card and see if it does the same thing? then get a different pair of speakers and see if it does the same thing also? Troubleshooting isn't rocket science.
Juice Box
9,615
well, I hit the mute button on my keyboard. and different speakers have the same problem. should I try putting the card in a different PCI slot?
TheLonelyPhoenix
5,594
Try a different PCI slot and get any cables near the card moved away from it... if neither works, RMA time.
And, oh yeah, wrong forum.
Wag
8,288
8
Go into the volume controls and mute either the line-in or microphone inputs. Sounds like feedback of some sort.
Chaotic42
35,391
2,514
Yeah.
I'd say mute everything that you don't use.
