Maximilian
Hi all. Ive been pondering on upgrading my sound card, or rather putting a sound card in my pc as it currently dosent really have one. Everythings ok on the AC97 thing it has but ive got 5 speakers and a sub woofer and a noticed that the prices of an Audigy 2 have gone down significantly since last time i checked. So i got a few questions
1. Its only £26! But it says "VALUE" so... what does that mean? does it mean its crap or somthing?
http://www.komplett.co.uk/k/ki.asp?sku=303733&cks=SPK
2. This ones £41 and isnt value. Is it significantly better than the above value one? If so why?
http://www.komplett.co.uk/k/ki.asp?sku=302657&cks=SPK
3. Last but not least, would it be worth buying either of these to replace my AC97 built in audio? Am i getting all i can get from these beefy speakers with AC97? theres a few cables from the subwoofer with nowhere to plug into so i figured im not 🙁
BTW if both of these suck and you have a better recommendation tell me but im a poor student so... ykno budget stuffs my type o thing 😀
