Sound card suggestion?
dimsumXP
9
I haven't been paying much to hardware for the past couple years and starting to put together a new rig. I purchased the ASUS P5N32-E SLI Plus 755, and I was wondering...
1) should I consider using a soundcard to replace it's onboard sound and
2) what's the cheapest card I can get that will still be better than what the motherboard comes with?
Thanks!
Cheezeit
3,298
Yoyoyahowsdajello (I hate typing your name :D), is that card a significant improvement over onboard sound? I have a Gigabyte DS3 rev 3.3 which has Realtek 888 or Azalia, something like that. Is the onboard I have bad, or will I not be able to tell the difference between onboard and dedicated if I use cheap Logitech x 230's?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Unless you have issues with the onboard, I would say don't bother upgrading the card with x-230s as the output device.
dimsumXP
9
I have some Creative/Cambridge DTT2000 5.1 speakers I got a long time ago.
So what's the verdict? Don't jack with onboard sound?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
You can if you want to, but if you're serious about increasing your sound quality, getting a good pair of speakers or headphones would be a bigger improvement.
Oyeve
22,076
887
I wholly concur. :)
