Here's my current specs:
AMD Athlon 550mhz
FIC SD-11
2x 128MB PC-100 SDRAM (generic)
Western Digital 5200rpm 8 gig HD
Western Digital 7200rpm 15 gig HD
Creative Labs Annhiliator 2 GeForce 2 GTS 32mb ram
Diamond MX300 Sound card
NetGear FA310TX NIC
RealMagic Mpeg Decoder card
Acer 40x CD rom (generic)
Toshiba 5x DVD-Rom Drive
KDS VS-195 19" monitor
Aura Aspect 20 satellite speakers
Aura Aspect 40 subwoffer
Whew. That said, I'm currently upgrading to:
AMD Athlon 800mhz CPU
Abit KA7 motherboard (KX133 chipset)
Upon reading these forums, I've learned that my current soundcard may be incompatable with the kx133 chipset. If this is the case, can you all help me decide a new sound card?
The new soundcard much match this criteria 🙂
PCI
Compatable with above specs
Good for gaming
$50-100 max.
I'm looking into the SB Live Value, but I was wondering if the SB PCI 512 was comparable, better, worse, etc?
Any information into soundcards (I've been out of the loop for awhile) and what is the best 'bang for your buck' would be most appreciated. Thanks!
~Cy
AMD Athlon 550mhz
FIC SD-11
NetGear FA310TX NIC
PCI
Good for gaming
$50-100 max.
~Cy
