Originally posted by: YOyoYOhowsDAjello
Originally posted by: TrapAckbarNow
all right, it sounds like I just need to get some nice 2.1 speakers, thanks
If you do end up doing this, it's going to sound a little odd if you hook up your current set as surround speakers.
You'll also be a bit limited if you want to get a 5.1 set going eventually. 5.1 is best for DVD watching because it will have a center channel for voices to come out of. If you don't watch movies on your computer though, then whatever
For music though, a good 2.0 / 2.1 set is the way to go.
If you can, go out to some stores in your area and see if they have any sets you can listen to.
The Logitech sets will tend to have boomy powerful subs compared to some other offerings. If you want a lot of bass, logitech is a good place to look.
