Sound Card problem...
ibex333
4,094
123
Any ideas? Do you think my sound card is dying?
I tried using my headphones and my speakers, but the same thing happens in both cases. It's always on the left.
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Repeatedly? I've had Creative sound cards for years and every one of them had produced pops and cracks occasionally, and now that you mention it they do seem to hit the left channel more often.
somethingsketchy
1,019
Installed any new drivers recently? The easiest solution would be to check your sound card drivers. The least favorable solution would be to RMA your sound card and get a replacement. Another idea would be to try your motherboard integrated sound and see if there are any problems there. May there is some sort of conflict between the integrated sound (mobo) and the discrete card (Sound Blaster).
