Sound card problem
Silentsc0rn
25
I have a soundbalster Audigy LS and ever since I installed the card and the drivers, when I start winamp 5 it will play a song for a little while then shut down my computer entirely. I use windows XP and have tried the older versions of winamp. It seems to do it more often now than before. Anyone know what the issue here is?
Ionizer86
5,292
Your computer used to be stable, and you've never made any changes to your config other than the card and drivers, right? No overclocking either?
Silentsc0rn
25
Yes it was stable and now it isnt. I have tried updating drivers for the card but there isnt any on the web site, so I only have the ones on the cd it came with.
Oyeve
22,055
880
I had a simular problem but the card I have is the audigy 2 ZS. My system was running fine with the old audigy I had then I got the ZS and installed the drivers and all sorts of funky things started to happen. I didnt notice until i got a pair of 5.1 headphones and noticed that I couldnt change the speaker setings to 5.1 using the SB software. Uninstalled the card software and tried reinstalling it and even weirder things would happen. I would run eax console and a completely diferent program would open. After trying dozens of things I ended up having to do a clean install of the OS because the registry became corrupt. I wish you the best of luck.
Oyeve
22,055
880
NokiaDude
3,966
When it comes to upgrades the best solution is to do a clean install of your OS. Totally gets rid of all problems with old drivers laying around.
