- Nov 6, 2004
- 324
- 0
- 0
Here's my system: LAN Party UT nF3 Gb (nForce 3 250 Gb chipset); 128 MB Geforce 6800, Athlon 64 3000+, 1024 MB RAM, Win XP Home w SP 2. All hardware has the latest drivers, Windows has the latest updates. I had some time ago stopped using the onboard sound, disabled it in BIOS, and installed an SB Live 5.1 I had. It worked just fine.
My wife lovingly bought me an Audigy 2 ZS for Christmas. I uninstalled the Creative software for the Live!, which automatically uninstalled the hardware profile in the device manager.
I stuck the Audigy 2 ZS in the next to last PCI slot. During installation the CD would autoplay, then a black screen that just seemed to be missing the window that opens detailing what's being installed, etc. The task bar was still visible. I would then get a message: Exception occured: error. Then I would have to CTRL ALT DEL to get the task manager to shut the program down. A reboot was never necessary. I tried switching the card to every available PCI slot, the same thing occured.
Then, I put the Live back in, which now wouldn't install either. The error message was as follows: "error occcured while launching the setup 0x080040801" The Live had worked just fine before. The Creative knowledge base was absolutely worthless. Any suggestions to get the Audigy working would be great. I don't think it's a bad card since now the Live is doing the same thing after working before. My suspicion is the uninstallation of the Creative software didn't get rid of everything and it'ss causing problems.
Now I'm back to using onboard sound. Yikes.
Thanks in advance.
Thanks in advance.
