Sound Card Help
Kill-Rill
21
I am trying to find a sound card that I can hook my sound system to. Meaning that I need a sound card that has sound +/- ports (the red and yellow once). I basically want to use my system speakers on my comp instead of my crappy comp speakers.
Thx
Workin'
5,309
Ummm... Never seen one that couldn't do that. If the card you get has a mini plug instead of the phono plugs you are looking for (which it likely will), go to Radio Shack to get an adapter that will change a single mini plug into dual phono plugs.
