Sound Card Help
HI, I am using the onboard sound of my Neo2 PLatinum. I have 2 cheap speakers and usually can't tell a difference from low to high sound. Is it worth it getting a cheap sound card? Will it improve performance much? I have an old Turtle Beach 16bit sound card that I might try. What is a good cheap sound card? (Very Cheap)
Originally posted by: DaveSimmons
No, you need good speakers before you'll hear any difference.
:thumbsup:
Better speakers make a bigger difference than better soundcards.
What's your budget?
