Sound Card for Z906 System
Fes69
Hey guys,
I'm getting my Logitech Z906 soon and I'd like to know what Sound Card I should get in order to get the most out of the 5.1 system.
I was looking at some Soundblaster :
X-Fi Titanium
X-Fi HD
Or the Asus Xonar Essence ST 24bits
I see that the X-fi HD is THX compatible, just like the Z906 speakers. I like the features on the XOnar but it looks expensive (200$ +)
What do you think will work best ?
Thanks
If your onboard has an optical (toslink) output use that unless you want to use EAX (which would only be for older games). However, I don't know if EAX works under Dolby Digital 5.1.
Hey guys,
X-Fi Titanium
X-Fi HD
Thanks
THX isn't a compatibility, it's a certification.
