sound card advice
garytmib
74
i would like to set up my computer to play mp3s through my stereo. i assume i would need i card that had rca outputs. i have no idea where to begin. can anyone give me some advice on this? tia
gary
AgaBoogaBoo
26,108
What kind of connection? Does the stereo have optical inputs?
If not, just go to Radio Shack and buy a small adapter from the audio output on the computer to RCA outputs
Burninator
129
if you get the right mobo, some have optical ports on them.
I know the IC7-MAX3 has 2 ( cuz i own it I know)
AngryKid
187
Yeah, do what AgaBooga said. Go to the Shack and get the phono plug to RCA adapter (and possible and phono extension cord, if necessary). Works like a charm.
tboneuls
Banned
Nov 17, 2001
384
I have done the same thing, so if you need anymore help, PM me. I use a 3.5" stereo headphone style connector to 2 rca jacks to hook up.... im not an audiophile, but an audio card with an optical output would be best... and for conntroling the comp i use a program called snowcrash.. http://www.mp3pirate.com/snowcrash/ it allow you to just have the comp by ur stereo ... no need for a monitor and keyboard and such... very cool. its a winamp plugin... web interface.. check it out. hope some of this helps
fell8
533
Wal-mart has the adapter described above, only cheaper and with a 6' cord. Try that one.
garytmib
74
thanks everyone, my stereo only has rca inputs and i do have the adapter, i'll give it a try.
gary
