Sound but no front panel display
coddy6
12
Hi guys. I accidentally connected my Panasonic bluray htib into the av receivers hdmi dvd input instead of the bd/dvd recorder hdmi input. Now iv lost the av receivers front panel display. Anyone know of any fix options. Cheers
mdram
1,512
208
any input should work
but other than that i would suggest
1. power off on
2. unplug for @ 10 min or so then plug in and turn on
3. microprocessor reset
if non of the above work well not sure
whats the model?
coddy6
12
Its a Panasonic sa-ht65 av receiver 5.1 ss ht. Tried power off and on. Ill try the ten min unplugging now. Wondering, how would I reset the microprocessor. Cheers
coddy6
12
1. power off on
whats the model?
Its a Panasonic sa-ht65 5.1 av receiver.
I read somewhere that there is something to do with hdmi handshake. Not sure what that means or weather it is relevant to this kind of issue.
mdram
1,512
208
when you said front panel, i assumed it was the display f the avr
do you mean the actual screen?
coddy6
12
Nah. Its red standby light goes off it boots up and sound is fine through the speakers. But the display on the front panel wouldn't light up even after I unplugged everything. Sorry to hassle you with the question. Just couldn't find any answers online anywhere. Lol
mdram
1,512
208
the display could just be bad, it happens. certain denon models are know for this
there is usually a fuse and or cap that go bad on those
involves some solder work
if the unit is old it may be time for an upgrade
coddy6
12
Was hoping it may just be the fuse. But it doesnt look like there is anything wrong with that. Damn. And looking inside doesnt seem to be anything burnt out and fried look to any boards. But im gunna take it to a guy I found today who does free quotes. See if its a minor or unrealistic to pay dilema. With that said it still sounds fantastic through the speakers. Just a shame that I cant access the menu to do any kind of custom speaker vol. Setups or all the different functions available in the unit. Lol. Alls good and thank you for the advice and the help. I will however replace the glass fuse and see how that goes. Cheers mdram.
nOOky
3,232
2,289
My avr has a dimmer function for the front panel I an turn the display down or even off, does your have that, and have you played with it's settings?
coddy6
12
Hi guys. Yeah even tried to sus that option. But without the front panel display I couldn't get the dim functions to work. Lol. I don't have a button on mine. Iv gotta go into a set up menu and use the units front panel buttons to navigate through the settings
