Sound Blaster Live! Value problem, please help!!!!!!!
DarkKnight
1,197
When I try to install Liveware on my Windows 98 and 2000, the installation says that there is no Sound Blaster Live in the computer, even though there is (device manager says that I have a Sound Blaster Live). Does anyone know why this is happening and how to fix it?
Another problem that I have is that there is no sound in Windows 2000, even though I have a sound card installed (the little speaker thing in the system tray is there also). In windows 98 it plays sound, but it doesn't work in 2K.
Siddhartha
12,505
Back when I had a AMD K6-2 450 I could never get a Soundblaster Live Value sound card to work properly. It would hang and repeat the same sound. What motherboard are you using?
