I used to have an original Sound Blaster Live X-Gamer w/ Live Drive. I traded out the card about a year ago for a Sound Blaster Live 5.1 (SB0220) and just never used the Live Drive with it.
Now I have a project where I need SPDIF out from the Live Drive, and when hooking it all up, I realized that the connection I usually used with my Live Drive (CT4860) is not the same as the SB Live 5.1 card - i.e. the newer card appears to have a small 10 pin connector rather than the nearly 40-pin conncetor on the old live drive.
Is there any way to make the old Live Drive compatible with the newer SB 5.1 card? Or perhaps, can I use the 1/8" Digital DIN via an adapter of some kind from Radio Shack?
There are a number of connectors on the live drive - J1 = AUD_EXT; J2 = DITIAL I/O Card; J3 = Digital DIN; J4 = AUD_EXT2, each with a different number of pins.
